Siebel Order Management Infrastructure Guide > Other Component Business Services for C/OM > ISS Disable Service >
DisableCheckCanInsert Method
This method skips the CanInsert check on the business component when new records are inserted. Arguments
- EnableCanInsert: [in] Y or N. When Y, the business component will skip the CanInsert check.
- InstanceName: [in] ISS business component instance name.
- BusCompName: [in] Name of the business component inside the ISS instance business object. The BusComp class should be derived from CSSBCOrderMgmtBase.
