Siebel Order Management Infrastructure Guide > Product Selection and Pricing Engine > Configuring PSP Procedures >
Creating PSP Procedures
PSP procedures are created in the same way that standard workflow processes are created. For information on creating workflow processes, see Siebel Business Process Designer Administration Guide. To create a PSP procedure
- In Siebel Tools, create a workflow process.
- To one or more of the workflow's steps, add Row Set Transformation Toolkit methods as input arguments.
CAUTION: PSP requires that each input property set for a PSP procedure step must also be defined as an output property set, even though the input property set is technically not output. This is required by a workflow performance optimization that makes sure input and output property sets are not copied when the transform method is invoked.
