Siebel Order Management Infrastructure Guide > Product Selection and Pricing Engine > About Tuning Performance of PSP > About Using the PSP Dynamic Look-Up Transform CacheThe Dynamic Look-Up transform has its own cache, named the PSP Dynamic Look-Up Transform Cache. You enable this for a particular step by setting Cache Enabled = Y, the same as for the generic PSP cache. No other cache-specific input arguments are supported for the Dynamic Look-Up Transform. The Dynamic Look-Up transform supports a preconfigured Clear Cache button; do not modify this preconfigured Clear Cache button. NOTE: This is the Clear Cache button in the Administration - Pricing screen, then Dynamic Matrix view mentioned above. The run-time event for this button is fixed. Do not try to configure this Clear Cache button as you would the Clear Cache button used by the PSP Generic Cache. |
Siebel Order Management Infrastructure Guide | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
