Siebel Order Management Infrastructure Guide > Service-Oriented Architecture >
About Business Services
A business service defines reusable business logic that can be executed within the Object Manager. Business services are the building blocks of C/OM functions. Generally, a business service:
  • Can be a built-in service that is defined in Siebel Tools or a run-time service that is defined in the Siebel client application by administrators
  • Can be based on the CSSService Class (standard business service) or on specialized classes (specialized business service)
    NOTE:  Specialized business services are used only by internal Siebel Engineering personnel. You should not use specialized business services unless their behavior is specifically documented.
  • Can be configured by properties or scripts (written in Siebel Visual Basic or Siebel eScript)
  • Can be used for generic code libraries that are called from other scripts
  • Can be referred to by commands associated with a menu item or toolbar button
Siebel Order Management Infrastructure Guide Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
