Siebel Order Management Infrastructure Guide > Variable Maps > Using Variable Maps > Migrating Variable Maps Between EnvironmentsYou can move variable maps between environments (such as from development to test) by using the Application Deployment Manager (ADM). For information about ADM, see Siebel Application Deployment Manager Guide. You can also export a specific version of a variable map using the Export Version applet menu in the Variable Map Version list. To import a variable map, navigate to the Administration - Products screen, then Joint Workspace view. This is a joint workspace for all types of versioned objects (signals, variable maps, products, product attributes, and so on). For more information on import/export, see Product Administration Guide. When exported, a variable map and its child variable maps are exported together into an XML file. When imported through the joint workspace, both parent and child variable maps will be imported and listed in the Joint Workspace view. NOTE: You must go to each of these variable maps separately to release them. |
Siebel Order Management Infrastructure Guide | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
