Siebel Order Management Infrastructure Guide > Variable Maps > Components of Variable Maps >
Configuring ISS Integration Objects
At run time, the user property of the business component that raised the signal determines which integration object to use. For each business component, there are various user properties (such as the property named Instance Uniform Name EAI Object:Catalog).
To configure ISS integration objects
  1. For the business component that raises the signal, set the value of the user property Instance Uniform Name EAI Object:[BusObj] to the integration object name, for example:
    In this example, Catalog refers to the business object that the business component is in at run time.
  2. From the integration object definition, use the value in Integration Object Component Name as the Instance Type.
    For example, use Header for the Quote business component in the Catalog business object.
    NOTE:  For each business object, each business component within it should have a unique Instance type—for example, no two business components within the Quote business object can be referred to as Header.
Siebel Order Management Infrastructure Guide Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
