Performance Tuning Guide > Tuning Siebel Configurator for Performance > Topology Considerations for Siebel Configurator > Running Siebel Configurator in the AOM ComponentYou can run Siebel Configurator in the AOM component, such as for Siebel Call Center. If a small number of concurrent users require configuration sessions, or there are a small number of customizable product models, then this deployment option may yield reasonable performance and make the most effective use of your hardware resources. With this option, you set all parameters for managing Siebel Configurator caching on each applicable AOM. For details, see Administering Siebel Configurator Caching. |
Performance Tuning Guide |
