Performance Tuning Guide > Tuning Siebel Workflow for Performance > Tuning Workflow Processes > Configuring Siebel Business Applications for Workflow PerformanceIn some cases, you may need to perform a comparison between different objects. Assume, for example, a service request is assigned to a candidate depending on the industry of the account associated with it. In this case, it is necessary to perform a query against Account to fetch the appropriate industries, or to check an industry against all the industries with which the account is associated. If the workflow process in this example is going to be evaluated frequently, consider exposing Account Industry on Service Request by the appropriate configuration in order to enhance workflow performance. |
Performance Tuning Guide |
