Performance Tuning Guide > Tuning Siebel Workflow for Performance > Tuning Workflow Process Manager for PerformanceThis section provides general approaches to tune and optimize performance of Workflow Process Manager. It is imperative to remember that every implementation of Siebel applications is unique, and so every use of workflow processes is also unique. It is in your best interest to test, continually monitor, and tune your workflow processes to achieve optimal throughput. You can follow the guidelines explained in the following sections: NOTE: The information provided in this section should be considered general background information. No attempt is made to detail the many variables that affect tuning at specific sites. This section is not a substitute for specific tuning recommendations made by Siebel Technical Services. |
Performance Tuning Guide |
