Pricing Administration Guide > Siebel Pricer Deployment and Integration >
External Integration of Siebel Pricer Using UAN
Use Siebel Universal Applications Network for integration if you want to replicate external data in your Siebel application.
To integrate Siebel Pricer with external applications using UAN
  1. Set up UAN to integrate the external application with your Siebel application, so data from the external application is replicated in Siebel quotes and orders.
  2. Set up pricing for Siebel quotes and orders in the usual way.
For more information about setting up integration using UAN, see the documentation provided with the UAN product that you purchased.
