Pricing Administration Guide > Creating Aggregate Discounts > Aggregate Discounts for Products with ComponentsAggregate discounts can be associated with component-based products. For example, for customers buying personal computers, you might create an aggregate discount so that if they buy both a CD-ROM drive and a floppy disk drive, they get a 10 percent discount on both drives. Aggregate discounts for product components work in the same general way as other aggregate discounts, but there are several additional constraints:
NOTE: If the same product appears multiple times as a component, then the different instances of the product may have different prices after all adjustments. In this case, the aggregate discount uses as its target price the instance of the product with the highest net price. For example, if a specific memory chip appears multiple places within a customizable computer system product, the highest calculated price for that memory chip will be used as the target price for all bundling discounts on that chip. |
Pricing Administration Guide |
