Pricing Administration Guide > Creating Attribute Adjustments > Upgrade Considerations for Attribute AdjustmentsWhen you upgrade from earlier versions of Siebel applications to version 7.8, use the On First Match (Action) argument of the Dynamic Lookup Transform. This argument makes attribute pricing that is defined in the Attribute Adjustments list in version 7.8 work the same way as attribute-based pricing feature in earlier versions. Without configuration, the pricing procedure provides the same functionality as in the earlier release. The Attribute Adjustments list can return multiple rows. The first row it returns will always be consistent with attribute pricing behavior in earlier versions. Using On Match arguments can return results that are not consistent with the behavior of versions earlier than 7.8. |
Pricing Administration Guide |
