Pricing Administration Guide > Creating Attribute Adjustments > Single and Multiple Type Attribute AdjustmentsAfter determining which attributes affect pricing, you must decide whether you need a single-attribute or multiple-attribute pricing adjustment table. When you create an Attribute Adjustment record, you use the Type field to specify that it is a single-condition or a multiple-condition adjustment as follows:
Single-condition attribute adjustments used for attribute pricing are relatively simple to create if you need them. For information, see Process of Creating an Attribute Adjustment. Before you begin creating multiple-condition attribute adjustments, you should decide on the following fields:
Pricing Administration Guide |
