Name |
Enter a meaningful name for this price list. Overwrite any system-generated name. If many price lists appear in your system, use a consistent naming convention to name all your price lists. |
Cost List |
Select the cost list you want to associate with this price list. |
Currency |
Enter the default currency for this price list. |
Shipping Method |
Select one default shipping method you want to associate with this price list. This appears as the default Shipping Method when a run-time user creates a quote or order that specifies this price list. |
Payment Terms |
Select one default set of payment terms to be associated with this price list. This selection appears as the default data for Payment Terms when a run-time user creates a Quote or Order that specifies this price list. |
Organization |
Select all the organizations that may have prices controlled by this price list. For more information see, Assigning Price Lists to Users. |
Ship Method |
Enter the mode used for shipping. |
Shipping Terms |
Select one default shipping charge protocol that you want to associate with this price list. This appears as the default Shipping Terms data when a run-time user creates a quote or order that specifies this price list. |
Effective From |
Enter the date and time when this price list will become effective. By default, Siebel Pricer assigns the current system date and time when you first create the Price List record. |
Effective To |
Enter the date and time when this price list will become ineffective. After this time, Siebel applications will not be able to use this price list. |
Updated By |
By default, Siebel Pricer assigns the user name used to log in to the current session in which this Price List record is created. |
Last Updated |
By default, Siebel Pricer assigns the current system date and time when you most recently saved this Price List record. |
Integration ID |
If this system-generated ID appears, you can use it as a unique identifier for this price list to assist with system integration tasks. The Integration ID field is used for system integration with external systems. This field is populated by Siebel EAI connectors. |
Pricing Procedure |
Select a custom pricing procedure. The pricing logic in this procedure will be applied to all the line items in the price list. Before this field is available, you must do the setup work described in Enabling Price List-Specific and Line Item-Specific Pricing Logic. |
Aggregate Discount Sequence |
Select an aggregate discount sequence in order to apply aggregate discounts to the price list. For more information, see Creating Aggregate Discounts. |
