Pricing Administration Guide > Creating Product Promotions > Process of Creating Product PromotionsTo create a product promotion, perform the following tasks:
NOTE: When you create the new Product Promotion record, a version named Work Space is automatically created and the Locked check box is automatically selected in Product Promotions screen > Versions view. This check box must be selected to change the Effective Dates of the promotion. You do not have to lock the version to change any other information about a promotion, but to see the changes at run time, the user must select Refresh Cache from an applet-level menu item of the promotion header form. For more information, see Managing Versions of Product Promotions. |
Pricing Administration Guide |
