Pricing Administration Guide > Creating Volume Discounts > Process of Setting Up a Volume Discount >
Creating a Volume Discount Record
A volume discount record provides the top-level information about a volume discount, including its name, whether it is a simple or tiered volume discount, its start and end dates, and its currency. CAUTION: If you delete a volume discount record, all references to this discount become invalid. Any price list line items that used this discount will no longer have a volume discount.
To create a volume discount record
- Navigate to the Administration - Pricing screen > Volume Discount view.
- Add a new record to the Volume Discounts list and complete the necessary fields. Some fields are described in the following table.
Name |
Enter a name for this volume discount. |
Discount Method |
Select a method from the picklist. The options are Simple and Tiered, as described in About Volume Discounts. |
Start Date |
Enter the date when this volume discount becomes effective. |
End Date |
Enter the date when this volume discount becomes ineffective. If the volume discount will not expire, leave this field blank. |
Currency |
Enter the currency in which the volume discount is applied. |
Exchange Date |
If you are converting currencies, enter the date for the currency exchange rate. The system will use the exchange rate on that day to convert currency. |
