Product Administration Guide > Siebel Configurator UI Properties >
Defining a UI Property
A UI property is a named variable and its value. UI properties modify the display of an item in a customizable product. You define a UI property by selecting the desired item in a customizable product and then defining one or more UI properties for it.
To define a UI property for a product
  1. Navigate to the Administration - Product screen, then the Product Definitions view.
  2. In the Products list, select and lock the desired product.
  3. In the Versions list, click the Work Space version.
  4. Click the Properties view tab.
  5. In the Explorer applet, click the name of the item for which you want to define a UI property.
  6. In Properties view, add a new record and complete the necessary fields, described in the following table.
    Field
    Comments
    Name
    Enter the name of the UI property variable. The variable can be predefined or user-defined.
    Value
    Enter a value for the variable. The value can be predefined or user-defined.
Product Administration Guide Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices.
