Product Administration Guide > Basic Product Administration > About Managing Product Records > Editing Product RecordsYou can change the content of any of the fields in a product record. Changing the class to which a product is assigned can change the attributes the product inherits. If the product's attributes change, you must revise all products with components in which the product is component. Verify that no configuration rules or scripts refer to attributes the product no longer has. CAUTION: If you change the name of the product, you must revise all products with components in which it is a component. Also revise configuration rules, UI design, and scripts that refer to the product. |
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
