Product Administration Guide > Basic Product Administration >
Creating a Product List Report
You can obtain a report that lists all the products in the product table. For each product, the report shows the following information:
  • Product name
  • Part number
  • Description
  • Unit of measure
  • Vendor
  • Product line
  • Effective start date
  • Effective end date
The product list displays in the Siebel Report Viewer. You can print the report or create an email attachment.
TIP:   The on-screen display of the report typically lists more products on each page than the Products list. Use the report to scan through the product table.
To create a product list report
  1. Navigate to the Administration - Product screen, then the Products view.
  2. Click the Reports button, which is near the top of the screen, and from the Reports menu, select Admin Product List.
  3. Use the dialog box to run the report.
    The Siebel Report Viewer appears and displays the Admin Product List report.
  4. Print the report or create an email attachment as desired.
Product Administration Guide Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices.
