Product Administration Guide > Product Bundles > Controlling How Bundle Components are ForecastWhen you add a product to a bundle, you can put a check mark in the Forecastable field. This adds the product to forecasts when the bundle is included in a quote and the user updates the related opportunity. To prevent bundle products from being added to product forecasts, do not put a check mark in the Forecastable field in Bundle Administration. A Forecastable check box is also available in the Quotes screen, Line Items view. This allows you to add or remove a bundle and its products from product forecasts within individual quotes. |
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
