Product Administration Guide > Products with Attributes > About Managing Attribute Definition Records >
Viewing Related Objects for Attribution Definitions
The Attribute Definition Cross References view allows you to view the objects that are related to an attribute definition, including:
  • Class. Product classes that contain the Attribute Definition
  • Smart Part Number. Smart Part Numbering that makes use of the Attribute Definition
To view related objects for an attribute definition
  1. Navigate to the Administration - Product screen, then the Attribute Definitions view.
  2. In the Attribute Definitions list, select the definition whose related objects you want to view.
  3. In the Versions list, click the version whose related objects you want to view.
  4. Click the Cross References view tab.
  5. In the Cross References link bar, click the Class or Smart Part Number link to view lists of related objects.
Product Administration Guide Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices.
