Product Administration Guide > Product and Promotion Eligibility and Compatibility > Defining Compatibility GroupsCompatibility groups are used to group compatibility rules that you create, for your own purposes. For example, you can create one group for product compatibility rules and one group for promotion compatibility rules. Alternatively, you can create one group for each product line. You can use any logical group that makes sense to your business. NOTE: Whatever the grouping, when compatibility is evaluated, all rules of type compatibility will be evaluated against all products, regardless of how they are logically grouped into Compatibility Groups. The same is true of rules of type eligibility. |
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
