Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
HasGenerics Method
This method returns generics and children flags for an item. A port has generics if the required cardinality is greater than the current cardinality and no default product is specified. Input Arguments
- ObjId. The unique identifier of the complex object root (for example, Quote ID).
- RootId. The unique identifier of the complex object root (for example, Quote Line Item row id).
- IntObjName. The name of the integration object.
- (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
- Port Item Id. The ID for the port item that will have either children or generics.
- Path. The path to the parent item of interest.
Output Arguments
- HasGenerics. Y is present if it does, not present if it does not.
- HasChildren. Y is present if it does, not present if it does not.
