Product Administration Guide > Siebel Configurator API Reference > APIs to Set Product and Attribute Values >
AddItem Method
This method adds an item to a specified port, creating a new instance of an item. If you want to change the quantity of an existing instance of an item, use SetItemQuantity. Input Arguments
- ObjId. The unique identifier of the complex object header.
- RootId. The unique identifier of the complex object root.
- (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
- (Optional) AutoResolve. Automatically resolves port cardinality violations. The default is N.
- Prod Item Id. The ID of the item (for example, ORIG_ID in S_PROD_ITEM table).
- Name. The name of the item.
- Product Id. The product id in S_PROD_INT table.
- Port Item Id. The ID of the item's port (for example, ORIG_ID of the port in S_PROD_ITEM table).
- Quantity. The item quantity.
- List Price. The item list price from Pricing Manager, which can be empty.
- Current Price. The current price from Pricing Manager, which can be empty.
- Parent Path. The path of the parent item the port belongs to.
Output Arguments
None.
