Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
SetInstance Method
This method creates a configuration session with a supplied property set. This permits configuration without directly writing to the database. The structure of the input property set does not need to correspond to a Siebel object, such as a quote that is indicated by the integration object specified.
Input Arguments
Same arguments as LoadInstance but also requires the property set indicating the state to load. This property set must have the SiebelMessage object as the only first level child.
Output Arguments
Same arguments as LoadInstance.
Product Administration Guide Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices.
