Product Administration Guide > Siebel Configurator in Release 6.x, 7.0 and 7.5 > Working with Resources in Release 6.x and 7.xResources are implemented in the same fashion for customizable products in release 7.0 and 7.5 as they were for models in release 6.x. You define resources in the Resource Designer, and then you write provide rules and consume rules that adjust the value of the resource. In release 7.0 and 7.5, you can also provide or consume amounts from a product attribute. In release 7.0 and 7.5, to enforce a resource or attribute so that its value does not drop below zero, you write a configuration rule that constrains the range of allowed values. |
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
