Product Administration Guide > Multilingual Translations for Product Data >
Translating the Product Description
Use these procedures to translate the product description. To translate the product description
- Navigate to the Administration - Product screen, then the Products view.
- Select a product whose description you want to translate.
- Click the Translations view tab.
- Add a new record to the Translations list and complete the necessary fields, described in the following table.
Language |
Displays the name of the language after you select the code. |
Code |
Select a language code. |
Description |
Enter the translation of the description. |
To translate the product description of customizable products
- Navigate to the Administration - Product screen, then the Product Definitions view.
- In the Product Definitions list, select a customizable product whose description you want to translate.
- In the Versions list, click the name of the Work Space version.
- Click the Display Names view tab.
- Add a new record to the Display Names list and complete the necessary fields, described in the following table.
Display Name |
Enter the translation of the name. |
Language |
