Product Administration Guide > Configuration Resources > Creating Configuration ResourcesWhen you create a resource, it is automatically added to a picklist. You can then add the resource to other customizable products by selecting it from the picklist. When you create a resource, it is added to a dialog box. You can copy this resource definition to other customizable products and edit the definition as needed. In turn, the edited definition is added to the dialog box. When you remove a resource from a customizable product, it is removed from the dialog box.
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
