Product Administration Guide > Configuration Constraints > Creating Groups of Related Configuration ConstraintsRelated constraints have the same basic construction but differ only in content. For example, you need to create a dozen exclude constraints of the form Product A excludes Product B. For each constraint the products will be different, but the basic construction is the same. There are several processes you can use to create groups of related constraints. For example, you create twelve exclude constraints in the following ways:
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
