Product Administration Guide > Siebel Configurator Scripts > Siebel Configurator Script Events and Methods > AddItem MethodThis method creates a new instance of an item and adds the specified quantity to the solution. For example, Item A exists in the solution and has quantity three. You use AddItem to add two more Item A to the solution. The new solution will contain two instances of Item A, one with quantity three, and one with quantity two. SyntaxAddItem (ParentObjPath, RelName, ProdName, Quantity) as Integer ItemsCan be used only for component products within the customizable product. ReturnsReturns the integration id of the item added if the add was successful. Returns 0 if the add fails. ExampleFor an example of using AddItem, see About Product Path in Siebel Configurator Scripts. |
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
