Product Administration Guide > Testing Products and Using Workspace Projects > Testing a Product with Components in Validation ModeYou can test a product with components in validation mode. This creates an instance of the product with components and presents its selection pages. You can test configuration constraints, the user interface, and pricing exactly as if you were a user. Validation mode can create an instance of the product with components based on the work space or on any released version of the product Validation mode uses a specific quote with following name convention: Customizable Product Validation Quote_[username] For example, if the username is SADMIN, the quote must be named Customizable Product Validation Quote_SADMIN. NOTE: If you make any fields required in the Quote business component, create the quote manually for each user (using the naming convention described here) and populate the required fields on each Quote before validating customizable products for the first time. Test the product with components in the following ways:
Validate a product with components at regular intervals while you are developing it. For example, after you enter a block of related configuration rules or after customizing the selection pages, go to validation mode and check your work. If your products with components are complex, consider developing written test plans that exercise all the configuration rules and all expected user behaviors. In particular, be sure to test for unexpected or incorrect user behaviors in order to rule out unexpected responses from the Siebel Configurator engine. You enter validation mode by clicking the Validate button, which located in the views where you work with products with components, such as the Product Versions view, and the Constraints view. To test a product with components in validation mode
Testing Product with Components PricingIf you want to test pricing, you must associate a price list with the Customizable Product Validation Quote_[username] .quote. This is a special quote provided for validating products with components. To test product with components pricing
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
