Siebel Public Sector Guide > Setting Up and Using Adobe Forms Integration >
Enabling Forms Integration for Additional Applets Using Siebel Tools
Adobe form integration is preconfigured as enabled on the following applets:
  • Contact List
  • PUB Immigration Contact List
  • PUB Immigration Credentials List
  • PUB Immigration Identity List
  • PUB Immigration Identity Form
  • PUB Immigration Contact Identity Form
Forms can also be generated based on other business objects, such as opportunities. Administrators can add Adobe form integration functionality to other Siebel application applets using Siebel Tools. For more information, see Siebel Tools Online Help and Using Siebel Tools.
This task is a step in Process of Setting Up Adobe Forms Integration.
To add form integration functionality to application applets
  1. In Siebel Tools, select the applet to which the forms integration menu option should be added.
  2. Add a new Applet Method Menu Item to the applet. In the Command field, select the Generate Form Command object.
