Siebel Public Sector Guide > Managing Immigration Contacts > Documenting Identity HistoryAs names and other aspects of identities change, the user can add new records to the contact Identity History view to document the changes. When a new identity record is created for a contact, it defaults to the primary identity, and its status is Active by default. After the Identity History record is saved, field values other than Status and Primary cannot be changed. Incorrect records can be marked (status) for later deletion by the administrator. Each identity record is given a unique identifier. The Identity ID field provides a link that the user can use to navigate to the Identities list view. This task is a step in Process of Managing Immigration Contacts. To add an identity record to Identity History
Siebel Public Sector Guide |
