Siebel Remote and Replication Manager Administration Guide > Administering Siebel Remote > Monitoring Siebel Remote Operations >
Monitoring Transaction Logs
Use the Administration - Siebel Remote views to monitor transaction logs.
To monitor transaction logs
  1. From the application-level menu, choose Navigate > Site Map > Administration - Siebel Remote.
  2. In the link bar, select Transaction Log.
    The Transaction Log list displays information about each transaction. The Operation Types for Siebel Remote transactions are as follows:
    Operation Type
    Description
    D
    Delete single row
    E
    Delete multiple rows
    F
    Delete cascading rows
    I
    Insert single row
    U
    Update single row
    V
    Update multiple rows
    X
    Insert set-based rows
    Y
    Update set-based rows
    Z
    Delete set-based rows
    G
    Merge multiple rows
    The fields in the Transaction Log list are described below.
    Field
    Description
    Node Number
    ID of the node that generated the transaction
    Operation
    Insert (I), update (U), delete (D), ...
    Item
    Table name of the transaction
    File Flag
    Flag to indicate whether the transaction is on a file attachment-related table
    Transaction ID
    Sequence number of the transaction
    Transaction Row ID
    ROW_ID of the transaction
    Transaction Updated
    Timestamp showing when the transaction was last updated
    The fields in the Detail form are described below, except for fields that are identical to those in the Transaction Log list.
    Field
    Description
    Transaction Updated by
    ROW_ID of the user who last updated the transaction
    Transaction Conflict ID
    ID of the conflict for the base table record
    Transaction Mod ID
    Version number of the base table record
    Visibility Level
    Visibility event level for the transaction: Enterprise(E), Limited(L)
    Visibility Event
    Whether the transaction is a visibility event
    Related Visibility Event
    Whether the transaction is a related visibility event
    Dock Object Code
    Dock object code of the transaction instance
    Primary Table Row ID
    ROW_ID of Primary table for the dock object instance
    Length (Long Log data)
    Real length of the long column of the transaction data
    Log Data 1, 2, 3, 4, long
    These fields hold transaction data
  3. To monitor transaction logs by operation, select Transaction Log By Operation from the link bar.
    The fields in the Transaction Log By Operation view provide information about the number of transactions for each operation using the following fields:
    Field
    Description
    Operation
    Type of the operation
    Number of transactions
    Total number of transaction for the operation type
  4. To monitor transaction logs by node, select Transaction Log By Node from the link bar.
    The Transaction Log By Node view displays the number of transactions for each node. A node is a Mobile Web Client or Regional server. The following fields appear in the view:
    Field
    Description
    Node Name
    Mobile client node name
    Total number of transactions for the operation type
    NOTE:  This view only shows transactions from mobile users and regional nodes. It does not include transactions created by nonmobile users who connect directly to the server.
  5. To monitor transaction logs by table, select Transaction Log By Table from the link bar.
    The Transaction Log By Table view displays the number of transactions for each table in the Siebel database. The following fields appear in the view:
    Field
    Description
    Item
    Table name
