Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Remote Server > Changing the Local Database Administrator PasswordA Siebel Remote server administrator can change the local DBA password on Mobile Web Clients. The password is set when the administrator generates the database template that will be used to create the local databases for those clients. To set the local DBA password, the administrator uses the New DBA password (NewDbaPwd) parameter of the Generate New Database server component. There are two ways to specify a value for this parameter:
If the administrator does not specify a value for this parameter by either of these methods, Generate New Database sets the local DBA password to the first 8 characters of the enterprise name if the name has 8 or more characters, or to the enterprise name concatenated with nnn, where nnn = 1234... as padding if the enterprise name has fewer than 8 characters. For example, by default, the local DBA password is set to ONECUSTO for an enterprise named OneCustomer or to SIEBEL12 for an enterprise named Siebel. The following procedure describes how to set a local DBA password for use on multiple occasions: To set a local DBA password for multiple uses of GenNewDb
For general information about generating database templates, see Generating a New Database Template. For a specific information about specifying parameters when the component is run, see Running the Generate New Database Component. |
Siebel Remote and Replication Manager Administration Guide |
