Siebel Remote and Replication Manager Administration Guide > Implementing Siebel Remote Server > Setting Siebel Remote System Preferences >
CSM Logging
Turns on logging of merge transactions. These are transactions created when connected users combine or merge two records of the same component, such as two opportunities into one. Information from this log can be used to relink orphaned records created when the merge process is crossed with an update process during a synchronization. This is only applicable if the installation uses Siebel Remote or Replication Manager.
