Siebel Remote and Replication Manager Administration Guide > Siebel Remote Concepts > Security and Authentication > Providing Security Adapter Authentication for Synchronizing the Local DatabaseAn authentication system is a data store outside the Siebel Database in which the information that is required to allow users to connect to a data source or to a server component is maintained. This information typically consists of database accounts and Siebel user IDs. A security adapter is a plug-in to the authentication manager. The security adapter uses the credentials entered by a user or supplied by an authentication service to retrieve the Siebel user ID, a database account, and, optionally, a set of roles from the authentication system. Security adapters can be used in authentication of Mobile Web Client synchronization sessions. For information about other authentication methods for synchronization, see Authentication for Synchronizing the Local Database. For context-independent guidelines and instructions for setting up security adapter authentication, see Security Guide for Siebel eBusiness Applications. To implement security adapter authentication for synchronizing the local database, be aware of the following considerations:
Siebel Remote and Replication Manager Administration Guide |
