Siebel Remote and Replication Manager Administration Guide > Siebel Remote Concepts > Conflict Detection and Resolution > Delete ConflictsA potential delete conflict arises whenever one of the database changes is to delete a row. A single rule applies to delete operations and overrides other transactions. Whenever Siebel Remote encounters a delete transaction, delete always wins whether or not the transaction is in conflict with another update. If one transaction updates a database row and another deletes the row, Siebel Remote ignores the update and deletes the row. NOTE: This rule supersedes the System Preferences Conflict Resolution rule set during initial implementation. When detecting delete conflicts, deleted records appear in the User Preferences screen > Remote Status view > Session Actions list after the user synchronizes. However, the deleted records appear only if the system preference MRG: User Friendly Notification is set to TRUE. See Setting Siebel Remote System Preferences for more information. |
Siebel Remote and Replication Manager Administration Guide |
