Siebel Remote and Replication Manager Administration Guide > Setting Up Mobile Web Clients > Using a Different Data SourceIf your organization requires data and applications to be stored on separate devices, you may wish to use a different data source from the one specified by default in the [Local] section of the CFG file. Use the following procedure to modify the information in the [Local] section. CAUTION: Be sure to modify the existing Local data source description in the CFG file. Do not add additional local data sources to the CFG file, as these are not supported. To use a different local data source
Siebel Remote and Replication Manager Administration Guide |
