Siebel Financial Services eBusiness Application Integration Guide > Overview >
Components of Siebel Financial Services eAI
Components of Siebel Financial Services eAI allows Siebel Financial Services eAI to support information exchange and communication between Siebel applications and other applications using XML technology while obeying industry XML requirements. Siebel Financial Services eAI provides an open toolkit and framework for customers to implement integration solutions with the availability of various components, such as Siebel Industry XML Connector Factory API, Siebel Connector for ACORD XML, and Siebel Connector for IFX XML that can be used individually or together with an EAI vendor's toolkit. The following section describes the components of Siebel Financial Services eAI.
