Security Guide for Siebel Business Applications > Configuring Access Control > Implementing Access Control >
Setting Up Divisions, Organizations, and Positions
This topic describes how to set up divisions, organizations, and positions.
This section describes how to set up divisions.
To set up a division
  1. From the application-level menu, choose Navigate > Site Map > Administration - Group > Internal Divisions.
    The Internal Divisions view appears.
  2. In the form, add a new record and complete the necessary fields.
    Some fields are described in the following table.
    Field
    Guideline
    Parent Division
    If this division is a subdivision, select the parent division. This allows a division to be associated with another division.
    Organization Type
    Indicates the type of organization, which controls where in the application a division will appear for selection purposes.
    For example, divisions with Organization Type = Service appear for selection in the Group field on the Service screen, Service Requests view.
    Organization Flag
    When selected, indicates that the division is also an organization. The system copies that division into the Organization view.
Setting Up Organizations
This section describes how to set up organizations.
To set up an organization
  1. From the application-level menu, choose Navigate > Site Map > Administration - Group > Organizations.
    The Organizations view appears.
    Field
    Guideline
    Parent Organization
    If this organization is a suborganization, select the parent organization. This allows an organization to be associated with another organization.
    Partner Flag
    Used for Siebel PRM. This is a read-only check box. When the box is checked, this indicates that the organization represents an external enterprise that is a partner of your company.
    NOTE:  Partners are registered and promoted to organizations using the Approved Partners view in the Administration - Partner screen, as described in Developing and Deploying Siebel eBusiness Applications.
Setting Up Positions
This section describes how to set up positions.
To set up a position
  1. From the application-level menu, choose Navigate > Site Map > Administration - Group > Positions.
    The Positions view appears.
    NOTE:  Most fields in the form are filled in automatically from the Employee record of the active employee. If you have not set up employees, you can associate them with positions later.
    Field
    Guideline
    Billing Product
    Used by Siebel Professional Services Automation.
    Compensable
    Used by Incentive Compensation.
    End Date
    Last day for the currently associated employee to be associated with this position.
    Last Name
    Select one or more employees to occupy the position. In the Assigned Employees dialog box, select the Primary field for the employee whom you want to make primary for this position.
    Parent Position
    If this position is a subposition, select the parent position. This allows a position to be associated with another position.
    Position Type
    Type of position. This field is informational and has no impact on visibility.
    Territory
    This field is a read-only multi-value group. You are not able to enter a value manually. For use by Siebel Assignment Manager.
Setting Up Responsibilities and Adding Views and Users
This section describes how to set up responsibilities and add views and users.
To define a responsibility and add views and users
  1. From the application-level menu, choose Navigate > Site Map > Administration - Application > Responsibilities.
    The Responsibilities view appears.
    NOTE:  By default, the Responsibilities view shows all responsibilities, regardless of organization. However, you may want to configure new views in Siebel Tools that restrict the visibility to responsibilities. For more information on configuring views, see Configuring Siebel Business Applications.
  2. In the Responsibilities list, add a new record and enter a name and description for the responsibility.
  3. In the Organization field, select an organization for the responsibility.
  4. To add views, do the following:
    1. In the Views list, add a new record.
    2. Select the appropriate views in the Add Views dialog box and click OK. When you add a view, set the flag Read Only View if it should be read-only for users with this responsibility.
      NOTE:  You can also delete views from the Views list.
  5. To add users, do the following:
    1. In the Users list, add a new record.
    2. Select the appropriate users in the Add Users dialog box and click OK.
      NOTE:  You can also delete employees from the Users list.
