Security Guide for Siebel Business Applications > Configuring Access Control > Implementing Access-Group Access Control >
Administering Access Groups
You can group parties of types Position, Organization, Household, and User List into access groups for the purpose of controlling their individual members' access to data.
You administer access groups in the Administration - Group screen by choosing Navigate > Site Map > Administration - Group > Access Groups. This screen contains the Access Groups tree and the Access Groups list.
The Access Groups tree lists all access groups on the second level of the tree. Each access group can be expanded to show its descendants. Therefore, an access group may appear at different levels in multiple branches of the tree.
An access group that has no parent access group is the top node of an access group hierarchy.
For information about access groups, see Access Control for Parties and About Access-Group Access Control.
Creating an Access Group
You can create an access group in the Administration - Group screen.
To create an access group
  1. From the application-level menu, choose Navigate > Site Map > Administration - Group > Access Groups.
    The Access Groups tree and the Access Groups list appear.
  2. In the Access Groups list, add a new record.
    A new access group record.
  3. Complete the following fields, then save the record. Use the guidelines below.
    Field
    Guideline
    Name
    Required. Provide a name for the access group.
    Group Type
    Pick Access Group or Partner Community. These labels denote conceptual differences. Functionally, they are the same.
    Parent Access Group
    Specify a parent access group from which this new group inherits access to data that the parent group has access to.
    The new access group also appears in the Access Groups tree.
Modifying an Access Group
You can modify an access group by adding or deleting members.
To add members to an access group
    The Access Groups list appears.
  2. In the Access Groups list, select an access group.
  3. In the Members list, add a new record.
    A pop-up list appears that contains positions, organizations, accounts, households, and user lists.
  4. Select one or more members, and then click OK.
    The selected members appear in the Members list.
  5. In the Access Groups list, save the record.
You can delete members from an access group similarly.
Modifying an Access Group Hierarchy
You can modify the hierarchy of an access group by changing an access group's parent.
To modify a hierarchy of access groups
  3. Click on the Parent Access Group field.
    The text box becomes editable and its entry is highlighted.
  4. Do one of the following to modify the hierarchy:
    • To make the access group the top node of its own hierarchy, delete the entry in the Parent Access Group field. Click Save.
    • From the Parent Access Group field, pick a new parent and click OK. Click Save.
      The Access Group tree is updated to reflect the access group's new position in a hierarchy.
