Security Guide for Siebel Business Applications > Physical Deployment and Auditing > Securing Siebel Reports Server >
Securing Communications Between the AOM and Actuate iServer
During report generation, Actuate iServer establishes a separate session to the AOM to obtain data for report generation. This communication can be encrypted by setting the desired encryption type (RSA or MSCRYTPO) for the Actuate Server Connect String parameter in the configuration file for the AOM. The following example specifies RSA as the encryption type to use:
Actuate Server Connect String = siebel.TCPIP.RSA.none://SiebelServerHost:SCBPort/EnterpriseServerName/XXXObjMgr_language
For details on setting this parameter, see the postinstallation tasks described in the Siebel Installation Guide for the operating system you are using.
