Security Guide for Siebel Business Applications > Physical Deployment and Auditing > Role of Siebel Server Load Balancing in Networking SecurityYou can load-balance your Siebel Servers, using either Siebel load balancing or a third-party HTTP load balancer. A third-party load balancer typically can provide additional security features, such as limiting TCP port exposure to a single port for multiple Siebel Servers. Single-port exposure allows you to consolidate network access for better port monitoring and security. It also provides simplified firewall configuration. You only have to configure one virtual port, not many. Additional security features provided by most third-party load balancers include:
For information on configuring load balancing for your Siebel deployment, see the Siebel System Administration Guide and Siebel Installation Guide for the operating system you are using. |
Security Guide for Siebel Business Applications |
