Security Guide for Siebel Business Applications > Web Single Sign-On Authentication >
User Specification Source
This option can be implemented in the following authentication strategy:
  • Web SSO authentication
In a Web SSO implementation, the SWSE derives the user's username from either a Web server environment variable or an HTTP request header variable. You must specify one source or the other.
CAUTION:  If your implementation uses a header variable to pass a user's identity key from the third-party authentication service, then it is the responsibility of your third-party or custom authentication client to set the header variable correctly. The header variable should only be set after the user is authenticated, and it should be cleared when appropriate by the authentication client. If a header variable passes an identity key to the Siebel authentication manager, and the trust token is also verified, then the user is accepted as authenticated.
To specify the source of the username
  • In the eapps.cfg file, provide the following parameter values in either the [defaults] section or the section for each individual application, such as, for example, [/eservice].
    • UserSpec = name of the variable. For example: REMOTE_USER, if UserSpecSource is set to Server. If UserSpecSource is set to Header, the value of UserSpec will be the variable that will be passed into the HTTP header; the name of the variable should not be prefaced with HTTP_.
    • UserSpecSource = Server, if you use a Web server environment variable.
    • UserSpecSource = Header, if you use an HTTP request header variable.
      NOTE:  If you use a header variable to pass the username from an Microsoft IIS Web server, first configure the Microsoft IIS Web server to allow anonymous access. You make this security setting for the default Web site in the Microsoft IIS Service Manager.
For information about setting parameters in the eapps.cfg file, see Parameters in the eapps.cfg File.
