Security Guide for Siebel Business Applications > Web Single Sign-On Authentication > Setting Up Web SSO: A Scenario >
Process of Implementing Web SSO
You must perform the tasks in the following process to implement Web SSO in this environment:
  1. Create protected virtual directories for Siebel Business Applications on the Web server machine. See Creating Protected Virtual Directories.
  2. Set up third-party Web SSO authentication.
  3. Set up a directory from which database accounts and the user's Siebel user ID can be retrieved.
  4. Create a database login for users who are authenticated externally. See Creating a Database Login.
  5. Set up the ADS. See Setting Up the Active Directory Server.
  6. Create three users in the ADS directory: a regular user, the anonymous user, and the application user. See Creating Users in the Directory.
  7. Add user records in the Siebel Database corresponding to the regular user and the anonymous user in the directory. See Adding User Records in the Siebel Database.
  8. Edit eapps.cfg file parameters. See Editing Parameters in the eapps.cfg File.
  9. For Developer Web Clients, edit the Siebel application's configuration file parameters. See Editing Parameters in the Application Configuration File.
  10. Edit Siebel Gateway Name Server parameters. See Editing Name Server Parameters.
  11. Restart the Siebel Server and the Web server. See Restarting Servers.
  12. Test the implementation. See Testing Web SSO Authentication.
