Security Guide for Siebel Business Applications > Security Features of Siebel Web Server Extension >
Configuring Secure Views
You can require URLs to use the HTTPS protocol for specific views in your Siebel application. NOTE: The ability to selectively specify secure views applies to standard interactivity applications only, not high interactivity applications.
The following factors determine whether the Siebel Web Engine verifies that requests for a view use the HTTPS protocol:
- The value (
TRUE or FALSE ) of the view's Secure attribute. For information about the Secure attribute for a view, see Configuring Siebel Business Applications.
- The value (
TRUE or FALSE ) of the SecureBrowse parameter, located in the [SWE] section of the application's configuration file, such as siebel.cfg.
- If
SecureBrowse is set to TRUE , then HTTPS is required for all views in the entire application, regardless of how the Secure attribute is set for individual views.
- If
SecureBrowse is set to FALSE , then HTTP is used for all views in the entire application, except for those views for which the Secure attribute is set to TRUE . Secure views require HTTPS.
If you plan to use the HTTPS protocol, remember the following:
- You can switch between secure and nonsecure views in Siebel customer applications, but not in employee applications (such as Siebel Call Center). For employee applications, if any views are to be secure, then all views must be secure. Set the value of
SecureBrowse to TRUE .
- Your Web server must be configured to support HTTPS.
For information about SSL in Siebel Business Applications, see Types of Encryption and Configuring Data Encryption.
