Security Guide for Siebel Business Applications > Security Adapter Authentication > About LDAP/ADSI Security Adapter AuthenticationSiebel Business Applications includes security adapters that are based on the LDAP and ADSI standards, allowing customers to use LDAP directory products or Microsoft Active Directory Server (ADS) for user authentication. In an implementation using LDAP or ADSI authentication, a Siebel-provided security adapter (or another Siebel-compliant adapter) authenticates a user's credentials against the directory and retrieves login credentials from the directory. The security adapter functions as the authentication service in this architecture. Security adapter authentication provides a user with access to the Siebel application for which the security adapter is configured. Different Siebel Business Applications may be configured to use different security adapters. LDAP/ADSI Authentication BenefitsLDAP/ADSI security adapter authentication can offer the following benefits:
Security Guide for Siebel Business Applications |
