Security Guide for Siebel Business Applications > Security Adapter Authentication > Installing LDAP Client SoftwareThis section provides instructions for installing the IBM LDAP Client and IBM GSKit.
NOTE: The IBM installer program you run refers to the IBM Directory Server, IBM Directory Server Client, or Client SDK. In this document, the applicable client module is referred to as the IBM LDAP Client. Siebel Business Applications use the IBM LDAP Client and GSKit software with all supported LDAP directory products, not just with IBM Directory Server. Consider the following requirements for the IBM LDAP Client installation into a Siebel environment:
Installation must be performed from a network image directory. For information about installing Siebel Servers, Siebel Developer Web Clients, and other modules, see the Siebel Installation Guide for the operating system you are using. This section also provides instructions for installing IBM GSK iKeyMan, a utility you use to generate certificate database files (CMS files). Certificate database files are required for Siebel Business Applications to communicate with LDAP directory servers over SSL. IBM GSK iKeyMan can be installed on any machine using a supported platform. If you require this module, you only need to install it once per deployment. NOTE: Statements in this section assume that you are installing the correct versions of the IBM software. For more information about third-party software, including supported version numbers for these IBM modules, see System Requirements and Supported Platforms on Siebel SupportWeb. Also refer to your vendor documentation. |
Security Guide for Siebel Business Applications |
