Security Guide for Siebel Business Applications > User Administration > Configuring Anonymous Browsing >
Configuring Views for Anonymous Browsing or Explicit Login
Even when a view is included in the responsibility for the anonymous user, the view is not accessible to unregistered users if the view is designated for explicit login. A view that is designated for explicit login requires the viewer to be a registered user who has been authenticated.
The following procedure is intended to present the main steps in a Siebel Tools task. For detailed information about modifying view properties in Siebel Tools, see Configuring Siebel Business Applications.
To set or remove the explicit login requirement for a view
  1. Open Siebel Tools.
  2. Choose Tools > Lock Project.
  3. In Object Explorer, select the View object type.
    The Views list appears.
  4. Select a view.
  5. For each view, set the Explicit Login property to TRUE for explicit login. Or, set it to FALSE to allow anonymous browsing.
  6. Recompile the Siebel repository file, and unlock the project.
